Ir para o conteúdo principal
LeapFrog Scribble and Write Display Screen Replacement
O que você precisa
    1. LeapFrog Scribble and Write Display Screen Replacement, Display Screen: passo 1, imagem 1 %32 LeapFrog Scribble and Write Display Screen Replacement, Display Screen: passo 1, imagem 2 %32
      • Turn your toy over.
      • Use a Phillips screwdriver to remove the nine case screws from the back of the toy.
      • Be careful to keep track of the screws.
      Pergunte ao FixBot
      Comentar
    2. LeapFrog Scribble and Write Display Screen Replacement: passo 2, imagem 1 %32
      • Carefully remove the back of the toy..
      Pergunte ao FixBot
      Comentar
    3. LeapFrog Scribble and Write Display Screen Replacement: passo 3, imagem 1 %32 LeapFrog Scribble and Write Display Screen Replacement: passo 3, imagem 2 %32
      • Use a Philips screwdriver to remove the two screws attached to the motherboard.
      • Remove the motherboard.
      Pergunte ao FixBot
      Comentar
    4. LeapFrog Scribble and Write Display Screen Replacement: passo 4, imagem 1 %32 LeapFrog Scribble and Write Display Screen Replacement: passo 4, imagem 2 %32
      • Remove the screen.
      • Remove the two pins from the bottom of the screen.
      Pergunte ao FixBot
      Comentar
    5. LeapFrog Scribble and Write Display Screen Replacement: passo 5, imagem 1 %32
      • Use a Phillips screwdriver to remove the screw from the green clip that holds the two screen layers together.
      Pergunte ao FixBot
      Comentar
    6. LeapFrog Scribble and Write Display Screen Replacement: passo 6, imagem 1 %32 LeapFrog Scribble and Write Display Screen Replacement: passo 6, imagem 2 %32
      • Separate the blue and the white films.
      • Clean both films with paper towel.
      • Make sure there are no dirty spots before putting the films back together.
      Pergunte ao FixBot
      Comentar
Conclusão
Shang
Membro desde: 02/10/16
328 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 1-5, Nance Spring 2016 Membro de USF Tampa, Team 1-5, Nance Spring 2016
USFT-NANCE-S16S1G5
3 Membros
Autoria de 20 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 15
Últimos 30 dias: 66
Ao todo: 5,159
