Ir para o conteúdo principal
LeapFrog LeapTV Controller Joy Stick Replacement
O que você precisa
  1. LeapFrog LeapTV Controller Joy Stick Replacement, Battery: passo 1, imagem 1 %32
    • Use the Metal Spudger to push the release clip on the battery cover.
  2. LeapFrog LeapTV Controller Joy Stick Replacement: passo 2, imagem 1 %32
    • Lift the cover off.
  3. LeapFrog LeapTV Controller Joy Stick Replacement: passo 3, imagem 1 %32
    • The battery holder is now visible with the removal of the cover.
  4. LeapFrog LeapTV Controller Joy Stick Replacement, Controller Joy Stick: passo 4, imagem 1 %32
    • Use the screwdriver to remove the eight 8.7 mm PH1 Phillips head screws.
  5. LeapFrog LeapTV Controller Joy Stick Replacement: passo 5, imagem 1 %32
    • Separate the top and bottom parts of the controller slightly.
  6. LeapFrog LeapTV Controller Joy Stick Replacement: passo 6, imagem 1 %32
    • Slide the cover on the back side of the controller covering the joy stick out of the way.
  7. LeapFrog LeapTV Controller Joy Stick Replacement: passo 7, imagem 1 %32
    • Use the screwdriver to remove the four 8.7 mm PH1 Phillips head screws.
  8. LeapFrog LeapTV Controller Joy Stick Replacement: passo 8, imagem 1 %32
    • Turn and lift the circuit board with button attacked out of the hole. Do not detach the circuit.
  9. LeapFrog LeapTV Controller Joy Stick Replacement: passo 9, imagem 1 %32
    • Hold the circuit board and button and pull the button off.
  10. LeapFrog LeapTV Controller Joy Stick Replacement: passo 10, imagem 1 %32
    • Joystick will now pop off.
Conclusão
Joshua Jones
Membro desde: 03/23/17
101 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S4-G2, Baechle Spring 2017 Membro de IUPUI, Team S4-G2, Baechle Spring 2017
IUPUI-BAECHLE-S17S4G2
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 8
Duração total: 755
