Ir para o conteúdo principal
LeapFrog LeapTV Controller Button Replacement
O que você precisa
  1. LeapFrog LeapTV Controller Button Replacement, Battery: passo 1, imagem 1 %32
    • Use the Metal Spudger to push the release clip on the battery cover.
  2. LeapFrog LeapTV Controller Button Replacement: passo 2, imagem 1 %32
    • Lift the cover off.
  3. LeapFrog LeapTV Controller Button Replacement: passo 3, imagem 1 %32
    • The battery holder is now visible with the removal of the cover.
  4. LeapFrog LeapTV Controller Button Replacement, Buttons: passo 4, imagem 1 %32
    • Use the screwdriver to remove the eight 8.7mm PH1 Phillips head screws.
  5. LeapFrog LeapTV Controller Button Replacement: passo 5, imagem 1 %32
    • Slightly lift up on the back cover until the handle covers are free to rotate.
  6. LeapFrog LeapTV Controller Button Replacement: passo 6, imagem 1 %32
    • Slide the the side of the handle facing you to the left to reveal the "A" and "B" button circuit board.
  7. LeapFrog LeapTV Controller Button Replacement: passo 7, imagem 1 %32
    • Use the screwdriver to remove the three 8.5mm PH1 Phillips head screws.
  8. LeapFrog LeapTV Controller Button Replacement: passo 8, imagem 1 %32
    • Lift up on the circuit board and move it to the side.
    • Be careful to not cause excess stress to the connecting wires when handling the circuit board. Excess stress can cause solder points to break.
  9. LeapFrog LeapTV Controller Button Replacement: passo 9, imagem 1 %32
    • Use the plastic opening tool to release the buttons from the controller casing.
  10. LeapFrog LeapTV Controller Button Replacement: passo 10, imagem 1 %32
    • Remove the "A" and "B" buttons by pulling up on one of the buttons.
  11. LeapFrog LeapTV Controller Button Replacement: passo 11, imagem 1 %32
    • Buttons are now removed.
Conclusão
Uma outra pessoa concluiu este guia.
Triston Fischer
Membro desde: 03/08/17
128 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S4-G2, Baechle Spring 2017 Membro de IUPUI, Team S4-G2, Baechle Spring 2017
IUPUI-BAECHLE-S17S4G2
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 347
