Introdução
The motherboard is the brain of the device and controls all of the functions. This guide is for those of whom that are looking to replace their LeapPad's motherboard due to damage or issues. Like always, take extra caution when handling the device when its components are exposed. It is important to follow the guide word-by-word to avoid performing the steps incorrectly so that no further damage results.
O que você precisa
Remove the barcode covering the two screws on the lower back of the Leap Pad.
Ferramenta utilizada nesse passo:Tweezers$4.99
Disconnect the battery using tweezers or your fingernails.
The battery is glued down, if available put some isopropyl alcohol around the edges of the battery to soften the glue.
Gently pry of the battery lose using a spudger or another thin prying tool.
Disconnect the three wires that will be visible on top of the motherboard. The wires need to be disconnected by pulling them up vertically.
