Introdução
The camera is a component of the LeapPad that isn't necessary to function properly, although not being able to take pictures can be a big hindrance. This guide walks through the steps to replace the camera. Once again, take caution when handling the opened device so that the cables and components do not suffer damage.
O que você precisa
Remove the barcode covering the two screws on the lower back of the Leap Pad.
Disconnect the three wires that will be visible on top of the motherboard. The wires need to be disconnected by pulling them up vertically.
Disconnect the ribbon cable attached to the camera itself by using tweezers.
