Ir para o conteúdo principal
Introdução
To replace the battery is a mild task to get to and can take up to 15 minutes to complete. A far warning, patience is key because the device itself is difficult to open . The only tools that will be needed will be a screwdriver and some tweezers .
  1. Flip over the Pad to its back side to begin the removal of the back panel. Begin by removing the blue rim along the edge of the device. It runs along the green silicone lining.
    • Flip over the Pad to its back side to begin the removal of the back panel.
    • Begin by removing the blue rim along the edge of the device. It runs along the green silicone lining.
    • This is very difficult to remove , so do be patient. To help remove the seal, both a metal spudger and plastic opening tool may be used.
    • Remove the pen from its place before starting to avoid tangling.
  2. Once the blue rim is removed, the 12 screws will be visible. Use the Phillips #1 screwdriver to unscrew all 12 screws.
    • Once the blue rim is removed, the 12 screws will be visible.
    • Use the Phillips #1 screwdriver to unscrew all 12 screws.
  3. Kits de reparo de android
    A new screen or battery is one kit away.
    Comprar agora
    Comprar agora
  4. Begin with the removal of  the battery from its place. Flip the black switch that is connecting the battery to the motherboard.
    • Begin with the removal of the battery from its place.
    • Flip the black switch that is connecting the battery to the motherboard.
    • Then pull gently and should disconnect.
  5. Remove the black and white ribbon structures from the side of the motherboard. Next, remove the three screws along the corners of the motherboard using the Phillips # 1 screwdriver. Next, remove the three screws along the corners of the motherboard using the Phillips # 1 screwdriver.
    • Remove the black and white ribbon structures from the side of the motherboard.
    • Next, remove the three screws along the corners of the motherboard using the Phillips # 1 screwdriver.
  6. Use a Phillips #1 screwdriver to unscrew the 7  screws  from the speaker with the  bronze plate sound board.
    • Use a Phillips #1 screwdriver to unscrew the 7 screws from the speaker with the bronze plate sound board.
    • Unscrew the 8 screws from the blue sub-panel.
  7. Take off the sub-panel exposing the motherboard. Flip the motherboard on its back side and flip the switch to remove the wide orange ribbon and  pull the twisted black and white wires from its place.
    • Take off the sub-panel exposing the motherboard.
    • Flip the motherboard on its back side and flip the switch to remove the wide orange ribbon and pull the twisted black and white wires from its place.
Conclusão
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 6
All Time: 134
