Ir para o conteúdo principal
LeapFrog LeapPad Ultimate Motherboard Replacement
O que você precisa
  1. LeapFrog LeapPad Ultimate Motherboard Replacement, Back Panel: passo 1, imagem 1 %32 LeapFrog LeapPad Ultimate Motherboard Replacement, Back Panel: passo 1, imagem 2 %32
    • Flip over the Pad to its back side to begin the removal of the back panel.
    • Begin by removing the blue rim along the edge of the device. It runs along the green silicone lining.
    • This is very difficult to remove , so do be patient. To help remove the seal, both a metal spudger and plastic opening tool may be used.
    • Remove the pen from its place before starting to avoid tangling.
  2. LeapFrog LeapPad Ultimate Motherboard Replacement: passo 2, imagem 1 %32 LeapFrog LeapPad Ultimate Motherboard Replacement: passo 2, imagem 2 %32
    • Once the blue rim is removed, the 12 screws will be visible.
    • Use the Phillips #1 screwdriver to unscrew all 12 screws.
  3. LeapFrog LeapPad Ultimate Motherboard Replacement, Motherboard: passo 3, imagem 1 %32 LeapFrog LeapPad Ultimate Motherboard Replacement, Motherboard: passo 3, imagem 2 %32
    • Begin with the removal of the battery from its place.
    • Flip the black switch that is connecting the battery to the motherboard.
    • Then pull gently and should disconnect.
  4. LeapFrog LeapPad Ultimate Motherboard Replacement: passo 4, imagem 1 %32 LeapFrog LeapPad Ultimate Motherboard Replacement: passo 4, imagem 2 %32 LeapFrog LeapPad Ultimate Motherboard Replacement: passo 4, imagem 3 %32
    • Remove the black and white ribbon structures from the side of the motherboard.
    • Next, remove the three screws along the corners of the motherboard using the Phillips # 1 screwdriver.
  5. LeapFrog LeapPad Ultimate Motherboard Replacement: passo 5, imagem 1 %32
    • Use a Phillips #1 screwdriver to unscrew the 7 screws from the speaker with the bronze plate sound board.
    • Unscrew the 8 screws from the blue sub-panel.
  6. LeapFrog LeapPad Ultimate Motherboard Replacement: passo 6, imagem 1 %32 LeapFrog LeapPad Ultimate Motherboard Replacement: passo 6, imagem 2 %32
    • Take off the sub-panel exposing the motherboard.
    • Flip the motherboard on its back side and flip the switch to remove the wide orange ribbon and pull the twisted black and white wires from its place.
Conclusão
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Ao todo: 706
