Ir para o conteúdo principal
LeapFrog LeapPad Ultimate Camera Replacement
O que você precisa
  1. LeapFrog LeapPad Ultimate Camera Replacement, Back Panel: passo 1, imagem 1 %32 LeapFrog LeapPad Ultimate Camera Replacement, Back Panel: passo 1, imagem 2 %32
    • Flip over the Pad to its back side to begin the removal of the back panel.
    • Begin by removing the blue rim along the edge of the device. It runs along the green silicone lining.
    • This is very difficult to remove , so do be patient. To help remove the seal, both a metal spudger and plastic opening tool may be used.
    • Remove the pen from its place before starting to avoid tangling.
  2. LeapFrog LeapPad Ultimate Camera Replacement: passo 2, imagem 1 %32 LeapFrog LeapPad Ultimate Camera Replacement: passo 2, imagem 2 %32
    • Once the blue rim is removed, the 12 screws will be visible.
    • Use the Phillips #1 screwdriver to unscrew all 12 screws.
  3. LeapFrog LeapPad Ultimate Camera Replacement, Camera: passo 3, imagem 1 %32
    • Remove the 3 screws on each corner of the motherboard
  4. LeapFrog LeapPad Ultimate Camera Replacement: passo 4, imagem 1 %32 LeapFrog LeapPad Ultimate Camera Replacement: passo 4, imagem 2 %32 LeapFrog LeapPad Ultimate Camera Replacement: passo 4, imagem 3 %32
    • Remove the ribbon on the bottom of the motherboard and the ribbon on the left side of the motherboard.
    • There will be a small black switch on top of the ribbons that you must flip to take them out.
  5. LeapFrog LeapPad Ultimate Camera Replacement: passo 5, imagem 1 %32
    • Remove the 3-pin connector on the top left side of the motherboard.
  6. LeapFrog LeapPad Ultimate Camera Replacement: passo 6, imagem 1 %32 LeapFrog LeapPad Ultimate Camera Replacement: passo 6, imagem 2 %32
    • Flip the motherboard to its back side and pinch the 2 green hooks to remove the camera cover
  7. LeapFrog LeapPad Ultimate Camera Replacement: passo 7, imagem 1 %32
    • Remove the ribbon connecting the camera to the motherboard. You have now taken out the camera and can replace it with a new one.
Conclusão
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Ao todo: 242
