Ir para o conteúdo principal
LeapFrog LeapPad Ultimate Back Panel Replacement
O que você precisa
  1. LeapFrog LeapPad Ultimate Back Panel Replacement, Back Panel: passo 1, imagem 1 %32 LeapFrog LeapPad Ultimate Back Panel Replacement, Back Panel: passo 1, imagem 2 %32
    • Flip over the Pad to its back side to begin the removal of the back panel.
    • Begin by removing the blue rim along the edge of the device. It runs along the green silicone lining.
    • This is very difficult to remove , so do be patient. To help remove the seal, both a metal spudger and plastic opening tool may be used.
    • Remove the pen from its place before starting to avoid tangling.
  2. LeapFrog LeapPad Ultimate Back Panel Replacement: passo 2, imagem 1 %32 LeapFrog LeapPad Ultimate Back Panel Replacement: passo 2, imagem 2 %32
    • Once the blue rim is removed, the 12 screws will be visible.
    • Use the Phillips #1 screwdriver to unscrew all 12 screws.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 1,189
