Ir para o conteúdo principal
LeapFrog LeapPad Platinum Motherboard Replacement
O que você precisa
  1. LeapFrog LeapPad Platinum Motherboard Replacement, Battery: passo 1, imagem 1 %32
    • Place your tablet on a flat surface with the screen facing down.
  2. LeapFrog LeapPad Platinum Motherboard Replacement: passo 2, imagem 1 %32 LeapFrog LeapPad Platinum Motherboard Replacement: passo 2, imagem 2 %32
    • Using a plastic opening tool, pry off the plastic border by inserting it in the space between the green bumper and the white plastic on the edge of the tablet.
    • The border snaps into place, so don't be too worried if you hear a cracking noise while prying it off.
  3. LeapFrog LeapPad Platinum Motherboard Replacement: passo 3, imagem 1 %32 LeapFrog LeapPad Platinum Motherboard Replacement: passo 3, imagem 2 %32
    • Remove the 11 Phillips screws (8.0 mm) located around the edge of the back cover with a Phillips screwdriver.
  4. LeapFrog LeapPad Platinum Motherboard Replacement: passo 4, imagem 1 %32
    • Pull the back cover off of your device.
  5. LeapFrog LeapPad Platinum Motherboard Replacement: passo 5, imagem 1 %32 LeapFrog LeapPad Platinum Motherboard Replacement: passo 5, imagem 2 %32 LeapFrog LeapPad Platinum Motherboard Replacement: passo 5, imagem 3 %32
    • Wedge a plastic opening tool underneath the battery and lift the battery up.
    • The battery is held in place by an adhesive strip, so it can be difficult to pry off.
  6. LeapFrog LeapPad Platinum Motherboard Replacement: passo 6, imagem 1 %32
    • The battery has red, black, and white wires that are all connected to the motherboard through a plastic clip. Unplug this plastic clip to fully remove the battery from your device.
  7. LeapFrog LeapPad Platinum Motherboard Replacement, Motherboard: passo 7, imagem 1 %32 LeapFrog LeapPad Platinum Motherboard Replacement, Motherboard: passo 7, imagem 2 %32
    • Locate the white ribbon cable connected to the motherboard.
    • Disconnect the cable by flipping up the metal tab on the connector and sliding the cable out.
  8. LeapFrog LeapPad Platinum Motherboard Replacement: passo 8, imagem 1 %32 LeapFrog LeapPad Platinum Motherboard Replacement: passo 8, imagem 2 %32
    • Locate the black ribbon cable which is connected to the motherboard.
  9. LeapFrog LeapPad Platinum Motherboard Replacement: passo 9, imagem 1 %32 LeapFrog LeapPad Platinum Motherboard Replacement: passo 9, imagem 2 %32
    • Remove the three 4.0 mm Phillips screws located in the corners of the motherboard.
  10. LeapFrog LeapPad Platinum Motherboard Replacement: passo 10, imagem 1 %32
    • Lift up the front edge of the motherboard.
    • Lift the volume-control button out of the device and set it aside.
  11. LeapFrog LeapPad Platinum Motherboard Replacement: passo 11, imagem 1 %32
    • Gently tug upwards on the red and black twisted wires located near the button you just removed to release the black rubber base they are connected to from the device.
    • This does not take much force, so it is likely that this piece will pop out of place when initially lifting the motherboard.
  12. LeapFrog LeapPad Platinum Motherboard Replacement: passo 12, imagem 1 %32 LeapFrog LeapPad Platinum Motherboard Replacement: passo 12, imagem 2 %32
    • Rotate your device 180 degrees so the the motherboard is on your right-hand side and gently lift the front edge of the motherboard to reveal an orange sheet of plastic.
    • Disconnect the orange sheet from the motherboard by lifting the metal tab on the connector (as you did for the cables in steps 1 and 2), and lift the motherboard completely out of the device.
Conclusão
Kaitlyn Kinerk
Membro desde: 01/26/16
263 Reputação
Autoria de 1 guia
Equipe
UW Tacoma, Team 1-5, Rose Winter 2016 Membro de UW Tacoma, Team 1-5, Rose Winter 2016
UWT-ROSE-W16S1G5
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 2,077
