Ir para o conteúdo principal
LeapFrog LeapPad Platinum Battery Replacement
O que você precisa
  1. LeapFrog LeapPad Platinum Battery Replacement, Battery: passo 1, imagem 1 %32
    • Place your tablet on a flat surface with the screen facing down.
  2. LeapFrog LeapPad Platinum Battery Replacement: passo 2, imagem 1 %32 LeapFrog LeapPad Platinum Battery Replacement: passo 2, imagem 2 %32
    • Using a plastic opening tool, pry off the plastic border by inserting it in the space between the green bumper and the white plastic on the edge of the tablet.
    • The border snaps into place, so don't be too worried if you hear a cracking noise while prying it off.
  3. LeapFrog LeapPad Platinum Battery Replacement: passo 3, imagem 1 %32 LeapFrog LeapPad Platinum Battery Replacement: passo 3, imagem 2 %32
    • Remove the 11 Phillips screws (8.0 mm) located around the edge of the back cover with a Phillips screwdriver.
  4. LeapFrog LeapPad Platinum Battery Replacement: passo 4, imagem 1 %32
    • Pull the back cover off of your device.
  5. LeapFrog LeapPad Platinum Battery Replacement: passo 5, imagem 1 %32 LeapFrog LeapPad Platinum Battery Replacement: passo 5, imagem 2 %32 LeapFrog LeapPad Platinum Battery Replacement: passo 5, imagem 3 %32
    • Wedge a plastic opening tool underneath the battery and lift the battery up.
    • The battery is held in place by an adhesive strip, so it can be difficult to pry off.
  6. LeapFrog LeapPad Platinum Battery Replacement: passo 6, imagem 1 %32
    • The battery has red, black, and white wires that are all connected to the motherboard through a plastic clip. Unplug this plastic clip to fully remove the battery from your device.
Conclusão
Brittney Cooper
Membro desde: 02/17/16
191 Reputação
Autoria de 1 guia
Equipe
UW Tacoma, Team 1-5, Rose Winter 2016 Membro de UW Tacoma, Team 1-5, Rose Winter 2016
UWT-ROSE-W16S1G5
Membros da 4
Autoria de 8 guias
3 comentários
Any advice on how to fix a stylus go a leap pad platinum? The top is damaged- can I use any stylus or another platinum stylus it just buy a mesh tip? I can’t seem to find any too buy???
Ann-Mariah Thurber - Responder
The stylus is PART of the LeapPad so, there's no way to replace it.
Luke Sawczak -
This was very helpful thank you 😁
Luke Sawczak - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 17
Duração total: 8,018
