Ir para o conteúdo principal
N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide
O que você precisa
  1. N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide, Leaf Spring Switch: passo 1, imagem 1 %32
    • Place the blaster upside down on the table, and remove the screw in the bottom of the handle.
    • Remove the battery door and take the batteries out.
  2. N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide: passo 2, imagem 1 %32 N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide: passo 2, imagem 2 %32 N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide: passo 2, imagem 3 %32
    • Set the blaster on its side with the screws facing up (the blaster will be placed on its left side). Remove all 14 phillips head, 8.2 mm screws and set them aside.
    • Lift the side of the blaster off exposing its internal parts.
  3. N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide: passo 3, imagem 1 %32
    • Work the trigger to ensure the problem is the switch not making a proper connection.
    • Remove the retaining phillips head 10.2 mm screw below the switch.
  4. N-Strike Nite Finder EX-3 Leaf Spring Switch Replacement Guide: passo 4, imagem 1 %32
    • Use a hot soldering iron to melt the solder of the two wires at the rear of the switch. Take note that the red wire leads from the top of the switch.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Michigan Tech, Team 5-8, Lauer Spring 2014 Membro de Michigan Tech, Team 5-8, Lauer Spring 2014
MTU-LAUER-S14S5G8
Membros da 3
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 21
Duração total: 1,964
