Ir para o conteúdo principal
Leader Impression i10A-LE Speakers Replacement
O que você precisa
  1. Leader Impression i10A-LE Speakers  Replacement, Speakers: passo 1, imagem 1 %32
    • Start with your Leader Impression i10A-LE with the word "Impression" closest to you and the camera in the top left corner.
  2. Leader Impression i10A-LE Speakers  Replacement: passo 2, imagem 1 %32 Leader Impression i10A-LE Speakers  Replacement: passo 2, imagem 2 %32 Leader Impression i10A-LE Speakers  Replacement: passo 2, imagem 3 %32
    • Start by prying the back off by using plastic opening tools
    • Using the plastic tools slide the flat end into the device.
    • Gently pry the back piece until you hear a popping noise.
    • Once the back is loose, remove it from the device and set aside.
  3. Leader Impression i10A-LE Speakers  Replacement: passo 3, imagem 1 %32 Leader Impression i10A-LE Speakers  Replacement: passo 3, imagem 2 %32 Leader Impression i10A-LE Speakers  Replacement: passo 3, imagem 3 %32
    • Use the spudger to pry both of the speakers from the tablet.
    • Follow both sets of speaker wires to the motherboard where they are connected.
    • Desolder the wire connections from the motherboard.
Conclusão
jcg
Membro desde: 11/14/16
101 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 126
