Ir para o conteúdo principal
Leader Impression i10A-LE Front Facing Camera Replacement
O que você precisa
  1. Leader Impression i10A-LE Front Facing Camera Replacement, Front Facing Camera: passo 1, imagem 1 %32 Leader Impression i10A-LE Front Facing Camera Replacement, Front Facing Camera: passo 1, imagem 2 %32
    • Start by prying the back off by using plastic opening tools.
    • Slide the flat end of the plastic tools into the seam device.
    • Using another plastic tool, slowly pry along the seam until the back pops off.
  2. Leader Impression i10A-LE Front Facing Camera Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Reminder to disconnect the battery.
    • Locate the Camera in the top left corner of the Leader Impression.
    • Using the tweezers, remove the bottom of the camera from the motherboard.
    • The top of the camera will detach as you pull upward.
  3. Leader Impression i10A-LE Front Facing Camera Replacement: passo 3, imagem 1 %32
    • Remove the camera from it's slot.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 119
