Ir para o conteúdo principal
Leader Impression i10A-LE Back Facing Camera Replacement
O que você precisa
  1. Leader Impression i10A-LE Back Facing Camera Replacement, Back Facing Camera: passo 1, imagem 1 %32 Leader Impression i10A-LE Back Facing Camera Replacement, Back Facing Camera: passo 1, imagem 2 %32
    • Start with your Leader Impression i10A-LE with the word "Impression" closest to you and the camera in the top left corner.
  2. Leader Impression i10A-LE Back Facing Camera Replacement: passo 2, imagem 1 %32 Leader Impression i10A-LE Back Facing Camera Replacement: passo 2, imagem 2 %32 Leader Impression i10A-LE Back Facing Camera Replacement: passo 2, imagem 3 %32
    • Start by prying the back off by using plastic opening tools.
    • Using the plastic tools slide the flat end into the device.
    • Gently pry the back piece until you hear a popping noise.
    • Once the back is loose, remove it from the device and set aside.
  3. Leader Impression i10A-LE Back Facing Camera Replacement: passo 3, imagem 1 %32 Leader Impression i10A-LE Back Facing Camera Replacement: passo 3, imagem 2 %32 Leader Impression i10A-LE Back Facing Camera Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Once the back is off, locate the back facing camera.
    • The camera will be in the top left corner.
    • Using the precision tweezers that are bent, gently grab the strip below the camera.
    • slowly lift up until the camera lifts from its spot.
  4. Leader Impression i10A-LE Back Facing Camera Replacement: passo 4, imagem 1 %32 Leader Impression i10A-LE Back Facing Camera Replacement: passo 4, imagem 2 %32 Leader Impression i10A-LE Back Facing Camera Replacement: passo 4, imagem 3 %32
    • Continue slowly lifting with the bent precision tweezers.
    • The bottom half of the camera strip will pop out.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 200
