Introdução
If the battery is too low for the device to turn on, replacing the battery may be necessary. If the device does not turn on after charging, the battery is most likely completely dead. When a battery is completely discharged, it oftentimes cannot be recharged. In this case, the battery is dead and needs to be replaced. No special skills or tools will be needed in order to complete this guide.
  1. Remove the two 3.5 mm Phillips #00 screws that are covered by the micro SD port.
    • Remove the two 3.5 mm Phillips #00 screws that are covered by the micro SD port.
    • This cover is adjacent to the volume button on the side of the Le Pan S.
  2. Insert the spudger between the front and back panel in order to pry them apart. Do this beside the volume button and the micro SD cover.
    • Insert the spudger between the front and back panel in order to pry them apart.
    • Do this beside the volume button and the micro SD cover.
    • Pry open the rest of the Le Pan S by dragging the spudger across the side.
  3. Kits de reparo de android
    A new screen or battery is one kit away.
    Comprar agora
    Comprar agora
  4. Once the front and back faces are completely separated, remove the back cover to reveal the inside components.
    • Once the front and back faces are completely separated, remove the back cover to reveal the inside components.
  5. Disconnect the battery from the circuitry and lay it out of the way. The best method to complete this is to pull the bundled cable connector out with your hands. Pull towards the wires and away from the electrical board. Use the spudger to further coax the cable out.
    • Disconnect the battery from the circuitry and lay it out of the way.
    • The best method to complete this is to pull the bundled cable connector out with your hands. Pull towards the wires and away from the electrical board. Use the spudger to further coax the cable out.
    • If you are replacing your battery, make sure to dispose of it properly.
Conclusão
2 outras pessoas concluíram este guia.
Maria Dole
Membro desde: 17-09-2015
374 Reputation
3 Guias de autoria
IUPUI, Team 2-1, Harley Fall 2015 Membro de IUPUI, Team 2-1, Harley Fall 2015
IUPUI-HARLEY-F15S2G1
5 Membros
10 Guias de autoria
4 Comments
where can I purchase a battery for a tc978
Timothy - Responder
Hi Timothy, Did you ever find out where to purchase a battery for your Le Pan S tablet?
jatrussel -
But what do I do when it's not the battery, but is the charger is so loose in the tablet, it won;t charge. Once in a while, I can get it to come on if I happened to hold the charger just right. So disgusting. Can this be fixed.? i have purchased two LePans and neither will charge.
cdboers - Responder
Where can I purchase the battery needed?????????????????
jatrussel - Responder
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 38
All Time: 4,551
