Introdução
After continuous use, it is very likely that fan blades will become damaged. Rather than discarding the entire fan because of one faulty component, it would be much easier, cheaper, and environmentally responsible to simply replace the blade.
This guide walks through the steps to replace a Lasko S16500 oscillating adjustable pedestal fan blade.
O que você precisa
Make sure that the fan is turned off and unplugged to avoid injury.
Remove the front grill cover by snapping it off.
