Ir para o conteúdo principal
Lasko 4910 Filter Replacement
O que você precisa
  1. Lasko 4910 Filter Replacement, Filter: passo 1, imagem 1 %32
    • On the backside of the fan, remove the top two 4mm Phillips #Y1 screws using PH 1 bit and Magnetic Driver
  2. Lasko 4910 Filter Replacement: passo 2, imagem 1 %32
    • Remove the top plastic portion of the fan
  3. Lasko 4910 Filter Replacement: passo 3, imagem 1 %32
    • Remove all four 4mm screws using the Phillips #1 screwdriver.
  4. Lasko 4910 Filter Replacement: passo 4, imagem 1 %32
    • Remove the filter from the fan.
Conclusão
Julie Ling
Membro desde: 10/22/18
159 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team S11-G2, Lore Fall 2018 Membro de UC Davis, Team S11-G2, Lore Fall 2018
UCD-LORE-F18S11G2
Membros da 4
1 Guia de autoria
Um comentário
Thank you for taking the time to do this. A great little guide for a fan that doesn't have a lot of support. Most details are looked over in online guide material. But this one was done with professional care.
Sincerely,
Davis Steffens
Seattle, WA
davissteffens@hotmail.com
PS: I Fix-It represents more than a company providing a service. I think you are reminding everyone that we have the right to Fix. Which in these weird times is a step needed.
Davis Steffens - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 17
Duração total: 1,611
