Ir para o conteúdo principal
Lasko 2002W Motor Replacement
O que você precisa
  1. Lasko 2002W Motor Replacement, Remove cover: passo 1, imagem 1 %32
    • Remove the front cage from the fan, exposing the screws.
  2. Lasko 2002W Motor Replacement, Remove screws: passo 2, imagem 1 %32
    • Remove the 3 screws holding the fan on to the motor housing using a 3/16" philips head screw driver. The length of the screwdriver does not matter.
  3. Lasko 2002W Motor Replacement, Remove motor screws: passo 3, imagem 1 %32
    • Remove the screws holding the motor onto the fan using the same 3/16" phillips head screwdriver. There are two screws.
    • Once removed, remove the metal part the screws were holding to the motor.
  4. Lasko 2002W Motor Replacement, Remove old motor.: passo 4, imagem 1 %32
    • Remove the old motor from the fan. No tools are required. The motor can simply be pulled out.
  5. Lasko 2002W Motor Replacement, Place new motor in motor housing.: passo 5, imagem 1 %32
    • Now that the old motor is removed, a new motor can be placed in the motor housing.
Conclusão
9 outras pessoas executaram este guia.
elsa
Membro desde: 10/11/14
382 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-39, Donnelly Fall 2014 Membro de USF Tampa, Team 1-39, Donnelly Fall 2014
USFT-DONNELLY-F14S1G39
1 Membro
1 Guia de autoria
Um comentário
What is the part number for replacement motor? Where do you get it?
Paul Dias - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 47
Duração total: 3,557
