Ir para o conteúdo principal
LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement
O que você precisa
  1. LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement, Swing Plate Fuser Drive (Swing Plate Assembly): passo 1, imagem 1 %32
    • Move your printer to a decent workspace.
    • Make sure your workspace is clean and you have plenty of room to rest pieces of the printer on as you remove them. You may want to consider having a magnetic board to keep screws on as well.
  2. LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 2, imagem 1 %32
    • Remove the lower paper tray (tray 2).
  3. LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 3, imagem 1 %32
    • Remove the back top panel.
  4. LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 4, imagem 1 %32
    • Remove the duplexer.
  5. LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 5, imagem 1 %32
    • Remove the rear output bin.
  6. LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 6, imagem 1 %32 LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 6, imagem 2 %32
    • Remove the fuser unit.
    • Pinch blue tab on each side of fuser. Pull away fuser.
  7. LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 7, imagem 1 %32
    • Remove the back lower cover.
  8. LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 8, imagem 1 %32 LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 8, imagem 2 %32 LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 8, imagem 3 %32
    • Remove the four screws from the top cover.
  9. LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 9, imagem 1 %32 LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 9, imagem 2 %32 LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 9, imagem 3 %32
    • Open the top cover and unlatch the catch.
    • The catch is circled in red. Be careful with it, as it is fragile. Push it in with a screwdriver to ease it loose from its place. Do not remove top cover until the catch is released.
  10. LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 10, imagem 1 %32
    • Remove the back right side panel.
  11. LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 11, imagem 1 %32 LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 11, imagem 2 %32
    • Remove the toner unit.
  12. LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 12, imagem 1 %32 LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 12, imagem 2 %32 LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 12, imagem 3 %32
    • Remove the top cover.
    • Should straight up with ease. If not, go back and check your work. Ensure that all four screws have been removed and that the catch has been released on the door hinge.
  13. LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 13, imagem 1 %32 LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 13, imagem 2 %32 LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 13, imagem 3 %32
    • Remove the left side panel.
    • Start by loosening back side from clips, working your way to the front. Be careful when removing the panel clip near the front printer door (slide panel carefully past door).
  14. LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 14, imagem 1 %32 LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 14, imagem 2 %32 LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 14, imagem 3 %32
    • Remove the two screws from the formatter and slide it free.
  15. LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 15, imagem 1 %32
    • Remove the small back left side plate cover.
  16. LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 16, imagem 1 %32 LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 16, imagem 2 %32
    • Remove the right side cover.
    • When removing the right side cover, notice plastic clip that attached to the power button assembly. Remember that this clip has to be reattached when you put the printer back together.
  17. LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 17, imagem 1 %32
    • Take stock and organize your removed printer pieces.
    • This is not an organized stack. Lol. Maybe take a break. This repair can be exhausting.
  18. LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 18, imagem 1 %32 LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 18, imagem 2 %32 LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 18, imagem 3 %32
    • Remove the two screws from left fan cover on right side of printer, pull fan free, disconnect fan cable.
    • Screws are circled in red.
  19. LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 19, imagem 1 %32 LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 19, imagem 2 %32 LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 19, imagem 3 %32
    • Disconnect the five power cables.
    • Cables are circled in red.
    • Proceed with caution; some of the cables need to have tabs pushed in before they will disconnect. Removing the cables will require some force, but avoid pulling out other tangled cables when removing the necessary ones.
  20. LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 20, imagem 1 %32 LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 20, imagem 2 %32 LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 20, imagem 3 %32
    • Remove the six screws.
    • Keep these screws well-labeled. Drawing yourself a map on a magnetized board or piece of paper can be helpful.
  21. LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 21, imagem 1 %32 LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 21, imagem 2 %32
    • Remove the grey power assembly slide.
    • Use a screwdriver to press circular grey tab. After the tab is released, pull out the grey power assembly.
  22. LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 22, imagem 1 %32 LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 22, imagem 2 %32
    • Guide all five disconnected cables through the black plastic cable guide.
    • Be very careful! The cable guide is small and the wires are fragile.
    • Try one cable at a time.
    • All five cables should end up on the inside of the printer.
  23. LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 23, imagem 1 %32 LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 23, imagem 2 %32
    • On the other side of the printer, remove six screws and the second fan plate. Disconnect the fan cable.
    • Fan cable (red and yellow) is attached underneath black plastic fan frame.
  24. LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 24, imagem 1 %32 LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 24, imagem 2 %32
    • Remove the power supply.
    • You should now be able to freely slide the power supply out horizontally. Make sure the power cables are tucked safely beneath the power tray.
  25. LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 25, imagem 1 %32 LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 25, imagem 2 %32
    • Remove the four screws from underside
    • Two of the screws are much easier to access than the others. You'll need to reach beneath to feel for the final two. Try to angle the end of your screwdriver away from you.
    • Only the visible screws are circled in red.
  26. LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 26, imagem 1 %32
    • Congratulations! You've made it to the swing plate!
  27. LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 27, imagem 1 %32 LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 27, imagem 2 %32 LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 27, imagem 3 %32
    • Remove the four screws holding the swing plate assembly in place.
    • Note that one screw is behind the white gear, which needs to be carefully removed by pushing down on the tab holding it in and easing it free.
  28. LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 28, imagem 1 %32
    • Carefully extract the swing plate assembly.
    • Congratulations!
  29. LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 29, imagem 1 %32
    • Install your replacement swing plate assembly with its four screws.
  30. LaserJet P4014DN Printer Swing Plate Fuser Drive (Swing Plate Assembly) Replacement: passo 30, imagem 1 %32
    • Follow these steps in reverse order and enjoy your replacement swing assembly.
    • “The merit of all things lies in their difficulty.” ― Alexandre Dumas
Conclusão
Uma outra pessoa concluiu este guia.
Jordan
Membro desde: 05/22/15
52 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 10
Duração total: 585
