Ir para o conteúdo principal
Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement
O que você precisa
  1. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement, Hose: passo 1, imagem 1 %32
    • Place the hair dryer on a sturdy surface with its backside facing up.
    • Using a Phillips #1 screwdriver, remove the six 12.7 mm screws from the back of the hair dryer.
  2. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: passo 2, imagem 1 %32
    • Open the hair dryer, and place the front cover to the side.
  3. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: passo 3, imagem 1 %32 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: passo 3, imagem 2 %32
    • Disconnect the clear tube from the hose cuff.
  4. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: passo 4, imagem 1 %32 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: passo 4, imagem 2 %32
    • Untwist the hose cuff off the fan opening.
  5. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: passo 5, imagem 1 %32 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: passo 5, imagem 2 %32
    • Pull the hose through the hose cuff until it reaches the top of the inner rim.
  6. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: passo 6, imagem 1 %32
    • Place and twist the hose cuff onto the fan opening.
  7. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: passo 7, imagem 1 %32 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: passo 7, imagem 2 %32 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: passo 7, imagem 3 %32
    • Slide the hose through the clear tube.
    • Slide the clear tube until it meets the rim of the hose cuff.
  8. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: passo 8, imagem 1 %32
    • Place the hair dryer's front cover on top of the back cover, leaving a finger's width space for the next step.
  9. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: passo 9, imagem 1 %32 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: passo 9, imagem 2 %32
    • Align the wire cover to the grooves of the left and right sides of the hair dryer.
    • Pull the cord through the wire opening.
    • Lightly press on the wire cover to secure its placement.
    • Push the front cover down to close the hair dryer.
  10. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: passo 10, imagem 1 %32 Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: passo 10, imagem 2 %32
    • Carefully flip the hair dryer on its backside.
    • Place a screw in each opening, and screw them until secure.
  11. Laila Ali Ionic Soft Bonnet Dryer LADR5604 Hose Replacement: passo 11, imagem 1 %32
    • Gently pull the hose to ensure it is secure.
Conclusão
Uma outra pessoa concluiu este guia.
Um comentário
Please provide resource for purchasing a replacement bonnet for the Laila Ali LADR5604
Joyce Johnson - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 29
Duração total: 769
