Ir para o conteúdo principal
LaCie Rugged USB-C Hard Drive Replacement
O que você precisa
  1. LaCie Rugged USB-C Hard Drive Replacement, Overview: passo 1, imagem 1 %32 LaCie Rugged USB-C Hard Drive Replacement, Overview: passo 1, imagem 2 %32 LaCie Rugged USB-C Hard Drive Replacement, Overview: passo 1, imagem 3 %32
    • This guide contains steps for the LaCie Rugged USB-C. There is no guarantee that the steps will be the same for different models.
  2. LaCie Rugged USB-C Hard Drive Replacement, Case Removal: passo 2, imagem 1 %32 LaCie Rugged USB-C Hard Drive Replacement, Case Removal: passo 2, imagem 2 %32
    • Remove the rubber case around the drive. You can just stretch it off.
  3. LaCie Rugged USB-C Hard Drive Replacement, Case Screws: passo 3, imagem 1 %32 LaCie Rugged USB-C Hard Drive Replacement, Case Screws: passo 3, imagem 2 %32
    • Remove these 4x Torx T8 screws
  4. LaCie Rugged USB-C Hard Drive Replacement, Case Removal: passo 4, imagem 1 %32 LaCie Rugged USB-C Hard Drive Replacement, Case Removal: passo 4, imagem 2 %32
    • Push on one side of the drive, where the white plastic is. Which side does not matter.
  5. LaCie Rugged USB-C Hard Drive Replacement, Preparing for Drive Removal: passo 5, imagem 1 %32 LaCie Rugged USB-C Hard Drive Replacement, Preparing for Drive Removal: passo 5, imagem 2 %32
    • Push GENTLY on the back side of the hard drive.
    • DO NOT push more than is necessary to get the drive above the white plastic, as shown in the second picture.
  6. LaCie Rugged USB-C Hard Drive Replacement, Drive Removal: passo 6, imagem 1 %32
    • Pull the drive gently out of the SATA connector.
Conclusão
6 outras pessoas executaram este guia.
9021007
Membro desde: 07/13/18
4.599 Reputação
Autoria de 25 guias
4 comentários
Thanks for confirming the T8 Torx security bit - I had to buy a set!
Andy Gibbons - Responder
Andy, how are you. ?
Am facing the same issue, did fixed yours ?
Dion Diogo Mar -
Hello, I have this same drive. My hard drive is fine, the internal case that has the SATA to USB C connector isn’t working. Is there a replacement for the adapter/inner case & the adapter?
James Causey - Responder
I have no idea of replacement of the LaCie internal case
But any generic USB C To SATA Adapter can be used - and very cheap on amazon too
Like in this link for example
Eoin -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 32
Últimos 30 dias: 114
Duração total: 4,502
