Ir para o conteúdo principal
LaCie Rugged USB-C Circuit Board Replacement
O que você precisa
  1. LaCie Rugged USB-C Circuit Board Replacement, Overview: passo 1, imagem 1 %32 LaCie Rugged USB-C Circuit Board Replacement, Overview: passo 1, imagem 2 %32 LaCie Rugged USB-C Circuit Board Replacement, Overview: passo 1, imagem 3 %32
    • This guide contains steps for the LaCie Rugged USB-C. There is no guarantee that the steps will be the same for different models.
  2. LaCie Rugged USB-C Circuit Board Replacement, Case Removal: passo 2, imagem 1 %32 LaCie Rugged USB-C Circuit Board Replacement, Case Removal: passo 2, imagem 2 %32
    • Remove the rubber case around the drive. You can just stretch it off.
  3. LaCie Rugged USB-C Circuit Board Replacement, Case Screws: passo 3, imagem 1 %32 LaCie Rugged USB-C Circuit Board Replacement, Case Screws: passo 3, imagem 2 %32
    • Remove these 4x Torx T8 screws
  4. LaCie Rugged USB-C Circuit Board Replacement, Case Removal: passo 4, imagem 1 %32 LaCie Rugged USB-C Circuit Board Replacement, Case Removal: passo 4, imagem 2 %32
    • Push on one side of the drive, where the white plastic is. Which side does not matter.
  5. LaCie Rugged USB-C Circuit Board Replacement, Preparing for Drive Removal: passo 5, imagem 1 %32 LaCie Rugged USB-C Circuit Board Replacement, Preparing for Drive Removal: passo 5, imagem 2 %32
    • Push GENTLY on the back side of the hard drive.
    • DO NOT push more than is necessary to get the drive above the white plastic, as shown in the second picture.
  6. LaCie Rugged USB-C Circuit Board Replacement, Drive Removal: passo 6, imagem 1 %32
    • Pull the drive gently out of the SATA connector.
  7. LaCie Rugged USB-C Circuit Board Replacement, Screw Removal: passo 7, imagem 1 %32
    • Remove this Phillips 00 screw from the board.
  8. LaCie Rugged USB-C Circuit Board Replacement, Board Removal: passo 8, imagem 1 %32
    • Slide the board out, making sure to keep any foam pieces intact.
    • Do not let any foam pieces get damaged. They are important.
Conclusão
5 outras pessoas executaram este guia.
9021007
Membro desde: 07/13/18
4.599 Reputação
Autoria de 25 guias
3 comentários
Where can i get a new board? thank you
Bar Avraham - Responder
Yes, where can we find a new board?
Vassilis Trigkas - Responder
Right, where can the part be purchased?????
James Causey - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 22
Últimos 30 dias: 65
Duração total: 1,553
