Ir para o conteúdo principal
LG env2 vx9100 Side Buttons Replacement
O que você precisa
  1. LG env2 vx9100 Side Buttons Replacement, Battery: passo 1, imagem 1 %32 LG env2 vx9100 Side Buttons Replacement, Battery: passo 1, imagem 2 %32 LG env2 vx9100 Side Buttons Replacement, Battery: passo 1, imagem 3 %32
    • Before disassembling your phone, be sure it is powered off to avoid minor electric shock or possible fire.
    • Place the phone face down on the table.
    • Use your fingernail or an opening tool to pull down the tab below the battery.
    • Lift the battery out.
  2. LG env2 vx9100 Side Buttons Replacement, Back Panel: passo 2, imagem 1 %32 LG env2 vx9100 Side Buttons Replacement, Back Panel: passo 2, imagem 2 %32
    • Locate the five rubber covers on the back panel of the phone.
    • Use the metal probe to pop out each rubber cover to reveal the screws underneath.
  3. LG env2 vx9100 Side Buttons Replacement: passo 3, imagem 1 %32 LG env2 vx9100 Side Buttons Replacement: passo 3, imagem 2 %32
    • Locate the six 2.5mm screws on the back panel of the phone.
    • Use a #00 Phillips screwdriver to remove each 2.5mm screw.
  4. LG env2 vx9100 Side Buttons Replacement: passo 4, imagem 1 %32 LG env2 vx9100 Side Buttons Replacement: passo 4, imagem 2 %32
    • Locate the seam around the edge of the phone.
    • Insert the plastic opening tool into the seam and pry gently to release the tabs.
    • Work your way around the phone until all tabs are released.
    • Remove the back panel of the phone.
  5. LG env2 vx9100 Side Buttons Replacement, Side Buttons: passo 5, imagem 1 %32 LG env2 vx9100 Side Buttons Replacement, Side Buttons: passo 5, imagem 2 %32
    • Locate the volume and camera buttons on the right side of the phone.
    • Lift up on the buttons to slide them out of the phone.
Conclusão
Reed Williston
Membro desde: 09/26/12
34 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 16-55, Forte Fall 2012 Membro de Cal Poly, Team 16-55, Forte Fall 2012
CPSU-FORTE-F12S16G55
Membros da 5
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 476
