Ir para o conteúdo principal
LG env2 vx9100 Inside Keyboard Replacement
O que você precisa
  1. LG env2 vx9100 Inside Keyboard Replacement, Battery: passo 1, imagem 1 %32 LG env2 vx9100 Inside Keyboard Replacement, Battery: passo 1, imagem 2 %32 LG env2 vx9100 Inside Keyboard Replacement, Battery: passo 1, imagem 3 %32
    • Before disassembling your phone, be sure it is powered off to avoid minor electric shock or possible fire.
    • Place the phone face down on the table.
    • Use your fingernail or an opening tool to pull down the tab below the battery.
    • Lift the battery out.
  2. LG env2 vx9100 Inside Keyboard Replacement, Back Panel: passo 2, imagem 1 %32 LG env2 vx9100 Inside Keyboard Replacement, Back Panel: passo 2, imagem 2 %32
    • Locate the five rubber covers on the back panel of the phone.
    • Use the metal probe to pop out each rubber cover to reveal the screws underneath.
  3. LG env2 vx9100 Inside Keyboard Replacement: passo 3, imagem 1 %32 LG env2 vx9100 Inside Keyboard Replacement: passo 3, imagem 2 %32
    • Locate the six 2.5mm screws on the back panel of the phone.
    • Use a #00 Phillips screwdriver to remove each 2.5mm screw.
  4. LG env2 vx9100 Inside Keyboard Replacement: passo 4, imagem 1 %32 LG env2 vx9100 Inside Keyboard Replacement: passo 4, imagem 2 %32
    • Locate the seam around the edge of the phone.
    • Insert the plastic opening tool into the seam and pry gently to release the tabs.
    • Work your way around the phone until all tabs are released.
    • Remove the back panel of the phone.
  5. LG env2 vx9100 Inside Keyboard Replacement, Inside Keyboard: passo 5, imagem 1 %32 LG env2 vx9100 Inside Keyboard Replacement, Inside Keyboard: passo 5, imagem 2 %32 LG env2 vx9100 Inside Keyboard Replacement, Inside Keyboard: passo 5, imagem 3 %32
    • Locate the silver strip connected to the logic board. The silver strip is closest to the bottom hinge of the phone.
    • Wedge the plastic opening tool in between the silver strip and the logic board.
    • Lift the plastic opening tool to separate the silver strip from the logic board.
  6. LG env2 vx9100 Inside Keyboard Replacement: passo 6, imagem 1 %32 LG env2 vx9100 Inside Keyboard Replacement: passo 6, imagem 2 %32
    • Wedge the plastic opening tool in between the logic board and the phone.
    • Lift the plastic opening tool to separate the logic board from the phone.
  7. LG env2 vx9100 Inside Keyboard Replacement: passo 7, imagem 1 %32 LG env2 vx9100 Inside Keyboard Replacement: passo 7, imagem 2 %32
    • Locate the back of the inside keyboard.
    • Take out the inside keyboard. You may need to use your fingernail to pull one of the corners up.
Conclusão
Reed Williston
Membro desde: 09/26/12
34 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 16-55, Forte Fall 2012 Membro de Cal Poly, Team 16-55, Forte Fall 2012
CPSU-FORTE-F12S16G55
Membros da 5
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 14
Duração total: 845
