Introdução
In this guide you will be removing the back panel and motherboard to access and remove the inside keyboard.
O que você precisa
Place the phone face down on the table.
Use your fingernail or an opening tool to pull down the tab below the battery.
Lift the battery out.
Locate the five rubber covers on the back panel of the phone.
Use the metal probe to pop out each rubber cover to reveal the screws underneath.
Locate the silver strip connected to the logic board. The silver strip is closest to the bottom hinge of the phone.
Wedge the plastic opening tool in between the silver strip and the logic board.
Lift the plastic opening tool to separate the silver strip from the logic board.
