Ir para o conteúdo principal
LG Xenon Speaker Replacement
O que você precisa
  1. LG Xenon Speaker Replacement, Back Case: passo 1, imagem 1 %32
    • Turn the phone so the back side is face up.
  2. LG Xenon Speaker Replacement: passo 2, imagem 1 %32 LG Xenon Speaker Replacement: passo 2, imagem 2 %32
    • Use your thumb to press on the small ridge at the bottom of the phone, then push upward to slide off the back casing.
  3. LG Xenon Speaker Replacement, Battery: passo 3, imagem 1 %32 LG Xenon Speaker Replacement, Battery: passo 3, imagem 2 %32
    • Use your index finger to pull the top of the battery out from the top center divot. Then pull the battery towards yourself to remove it from the compartment.
  4. LG Xenon Speaker Replacement, Motherboard: passo 4, imagem 1 %32 LG Xenon Speaker Replacement, Motherboard: passo 4, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the six 2.4mm screws, which secure the back panel.
  5. LG Xenon Speaker Replacement: passo 5, imagem 1 %32
    • Push a spudger or small tool under the inner edge of the back panel and gently pry upward to separate it from the main body.
  6. LG Xenon Speaker Replacement: passo 6, imagem 1 %32 LG Xenon Speaker Replacement: passo 6, imagem 2 %32
    • Pop off the camera, lock, and volume buttons from the side of the phone using tweezers.
  7. LG Xenon Speaker Replacement: passo 7, imagem 1 %32 LG Xenon Speaker Replacement: passo 7, imagem 2 %32
    • Use the Phillips #00 screwdriver to remove the two 3mm screws, which secure the motherboard.
  8. LG Xenon Speaker Replacement: passo 8, imagem 1 %32 LG Xenon Speaker Replacement: passo 8, imagem 2 %32
    • Carefully lift and remove the motherboard from the main body.
    • The connector cable will still be attached to the motherboard. Any damage to the connector cable may permanently disable the phone.
  9. LG Xenon Speaker Replacement: passo 9, imagem 1 %32 LG Xenon Speaker Replacement: passo 9, imagem 2 %32
    • Carefully unclip the metal tab to separate the connector cable from the motherboard.
  10. LG Xenon Speaker Replacement: passo 10, imagem 1 %32 LG Xenon Speaker Replacement: passo 10, imagem 2 %32
    • Once the connector cable is detached from the motherboard, you have successfully removed the motherboard from the phone.
  11. LG Xenon Speaker Replacement, Keyboard: passo 11, imagem 1 %32
    • Turn the motherboard over and carefully remove the keypad from the motherboard.
    • The keyboard may be sitting loosely in the case (not attached to the motherboard). Carefully remove keyboard from case.
  12. LG Xenon Speaker Replacement, LCD: passo 12, imagem 1 %32
    • After removing the motherboard and keyboard, unscrew eight 1.6mm Phillips #00 screws in the middle of the phone.
  13. LG Xenon Speaker Replacement: passo 13, imagem 1 %32
    • Remove slider piece.
    • Pay close attention that you don’t lose the spring.
    • Carefully remove the spring.
  14. LG Xenon Speaker Replacement: passo 14, imagem 1 %32 LG Xenon Speaker Replacement: passo 14, imagem 2 %32
    • Remove six 2.25mm Phillips #00 screws along the outside of the case.
  15. LG Xenon Speaker Replacement: passo 15, imagem 1 %32 LG Xenon Speaker Replacement: passo 15, imagem 2 %32
    • Using the plastic opening tool, carefully open and remove the case. Slide the tool along the edge and pry upwards to open.
  16. LG Xenon Speaker Replacement: passo 16, imagem 1 %32
    • Remove the black electrical tape holding the LCD to the screen.
  17. LG Xenon Speaker Replacement: passo 17, imagem 1 %32
    • Un-clasp the small tab in the top right corner.
  18. LG Xenon Speaker Replacement: passo 18, imagem 1 %32 LG Xenon Speaker Replacement: passo 18, imagem 2 %32 LG Xenon Speaker Replacement: passo 18, imagem 3 %32
    • Unhook the LCD from tabs on the bottom using the plastic opening tool.
    • Remove the LCD. Be careful, the LCD screen is fragile.
  19. LG Xenon Speaker Replacement, Speaker: passo 19, imagem 1 %32 LG Xenon Speaker Replacement, Speaker: passo 19, imagem 2 %32
    • The speaker is attached to the top of the LCD.
Conclusão
Uma outra pessoa concluiu este guia.
Micaela Saqui
Membro desde: 04/19/12
78 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 9-41, Regan Spring 2012 Membro de Cal Poly, Team 9-41, Regan Spring 2012
CPSU-REGAN-S12S9G41
5 Membros
Autoria de 19 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 50
Ao todo: 1,121
