Ir para o conteúdo principal
LG Xenon Microphone Replacement
O que você precisa
  1. LG Xenon Microphone Replacement, Back Case: passo 1, imagem 1 %32
    • Turn the phone so the back side is face up.
    Pergunte ao FixBot
    Comentar
  2. LG Xenon Microphone Replacement: passo 2, imagem 1 %32 LG Xenon Microphone Replacement: passo 2, imagem 2 %32
    • Use your thumb to press on the small ridge at the bottom of the phone, then push upward to slide off the back casing.
    Pergunte ao FixBot
    Comentar
  3. LG Xenon Microphone Replacement, Battery: passo 3, imagem 1 %32 LG Xenon Microphone Replacement, Battery: passo 3, imagem 2 %32
    • Use your index finger to pull the top of the battery out from the top center divot. Then pull the battery towards yourself to remove it from the compartment.
    Pergunte ao FixBot
    Comentar
  4. LG Xenon Microphone Replacement, Motherboard: passo 4, imagem 1 %32 LG Xenon Microphone Replacement, Motherboard: passo 4, imagem 2 %32
    • Use a Phillips #00 screwdriver to remove the six 2.4mm screws, which secure the back panel.
    Pergunte ao FixBot
    Comentar
  5. LG Xenon Microphone Replacement: passo 5, imagem 1 %32
    • Push a spudger or small tool under the inner edge of the back panel and gently pry upward to separate it from the main body.
    Pergunte ao FixBot
    Comentar
  6. LG Xenon Microphone Replacement: passo 6, imagem 1 %32 LG Xenon Microphone Replacement: passo 6, imagem 2 %32
    • Pop off the camera, lock, and volume buttons from the side of the phone using tweezers.
    Pergunte ao FixBot
    Comentar
  7. LG Xenon Microphone Replacement: passo 7, imagem 1 %32 LG Xenon Microphone Replacement: passo 7, imagem 2 %32
    • Use the Phillips #00 screwdriver to remove the two 3mm screws, which secure the motherboard.
    Pergunte ao FixBot
    Comentar
  8. LG Xenon Microphone Replacement: passo 8, imagem 1 %32 LG Xenon Microphone Replacement: passo 8, imagem 2 %32
    • Carefully lift and remove the motherboard from the main body.
    • The connector cable will still be attached to the motherboard. Any damage to the connector cable may permanently disable the phone.
    Pergunte ao FixBot
    Comentar
  9. LG Xenon Microphone Replacement: passo 9, imagem 1 %32 LG Xenon Microphone Replacement: passo 9, imagem 2 %32
    • Carefully unclip the metal tab to separate the connector cable from the motherboard.
    Pergunte ao FixBot
    Comentar
  10. LG Xenon Microphone Replacement: passo 10, imagem 1 %32 LG Xenon Microphone Replacement: passo 10, imagem 2 %32
    • Once the connector cable is detached from the motherboard, you have successfully removed the motherboard from the phone.
    Pergunte ao FixBot
    Comentar
  11. LG Xenon Microphone Replacement, Microphone: passo 11, imagem 1 %32 LG Xenon Microphone Replacement, Microphone: passo 11, imagem 2 %32
    • The microphone is located on the bottom corner of the motherboard.
    • Take caution when repairing the microphone to not damage the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Katy Conlin
Membro desde: 04/17/12
145 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 9-41, Regan Spring 2012 Membro de Cal Poly, Team 9-41, Regan Spring 2012
CPSU-REGAN-S12S9G41
5 Membros
Autoria de 19 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 12
Últimos 30 dias: 32
Ao todo: 1,377
