Ir para o conteúdo principal
LG Xenon Keyboard Replacement
O que você precisa
  1. LG Xenon Keyboard Replacement, Back Case: passo 1, imagem 1 %32
    • Turn the phone over so the back side is facing you.
  2. LG Xenon Keyboard Replacement: passo 2, imagem 1 %32 LG Xenon Keyboard Replacement: passo 2, imagem 2 %32
    • Placing your thumb on the bottom of the phone, apply pressure to the small ridge in the middle of the phone and push upward towards the camera.
    • The back casing should slide off.
  3. LG Xenon Keyboard Replacement, Battery: passo 3, imagem 1 %32 LG Xenon Keyboard Replacement, Battery: passo 3, imagem 2 %32
    • Using your index finger, pull the top of the battery out first. Place your finger at the top center of the battery in the gap that is provided. Then pull the battery towards yourself.
    • The battery should easily fall out after the top of the battery has been pulled out.
  4. LG Xenon Keyboard Replacement, Motherboard: passo 4, imagem 1 %32 LG Xenon Keyboard Replacement, Motherboard: passo 4, imagem 2 %32
    • Unscrew the six 2.4mm Phillips #00 screws (three on the left and three on the right of the phone) to remove the inner back case.
  5. LG Xenon Keyboard Replacement: passo 5, imagem 1 %32
    • Once all six screws are removed, use the plastic opening tool to carefully pry apart the inner back case. Push the plastic tool underneath the case. Carefully push upward, with the tool, while moving it around the case.
  6. LG Xenon Keyboard Replacement: passo 6, imagem 1 %32 LG Xenon Keyboard Replacement: passo 6, imagem 2 %32
    • Remove the camera, lock, and volume buttons from the side of the phone.
  7. LG Xenon Keyboard Replacement: passo 7, imagem 1 %32 LG Xenon Keyboard Replacement: passo 7, imagem 2 %32
    • Carefully remove the two 3mm Phillips #00 screws (one on the top and one on the bottom) that are attaching the motherboard to the phone.
  8. LG Xenon Keyboard Replacement: passo 8, imagem 1 %32 LG Xenon Keyboard Replacement: passo 8, imagem 2 %32
    • For this next step, carefully lift and remove the motherboard.
    • A connector cable will still be connected to the motherboard upon removing it.
    • Damage to the connector cable will permanently disable phone.
  9. LG Xenon Keyboard Replacement: passo 9, imagem 1 %32 LG Xenon Keyboard Replacement: passo 9, imagem 2 %32
    • Carefully unclip the silver metallic tab from the motherboard.
  10. LG Xenon Keyboard Replacement: passo 10, imagem 1 %32 LG Xenon Keyboard Replacement: passo 10, imagem 2 %32
    • Once the cable is removed, you have successfully disassembled the motherboard of your phone.
  11. LG Xenon Keyboard Replacement, Keyboard: passo 11, imagem 1 %32
    • Turn the motherboard over and carefully remove the keypad from the motherboard.
    • The keyboard may be sitting loosely in the case (not attached to the motherboard). Carefully remove keyboard from case.
Conclusão
Uma outra pessoa concluiu este guia.
Micaela Saqui
Membro desde: 04/19/12
39 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 9-41, Regan Spring 2012 Membro de Cal Poly, Team 9-41, Regan Spring 2012
CPSU-REGAN-S12S9G41
Membros da 5
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 791
