Ir para o conteúdo principal
LG X Style Speaker Replacement
O que você precisa
  1. LG X Style Speaker  Replacement, Screen: passo 1, imagem 1 %32 LG X Style Speaker  Replacement, Screen: passo 1, imagem 2 %32
    • With a Phillips #000 screwdriver, remove the twelve 3mm screws.
  2. LG X Style Speaker  Replacement: passo 2, imagem 1 %32 LG X Style Speaker  Replacement: passo 2, imagem 2 %32 LG X Style Speaker  Replacement: passo 2, imagem 3 %32
    • Create a gap with plastic opening tool by applying pressure between glass screen and plastic edge of device.
    • Slide prying tool around entire device beginning toward the top.
    • Lift off and remove the screen from the device.
  3. LG X Style Speaker  Replacement, Battery: passo 3, imagem 1 %32
    • Power down the device and make sure that it is turned off.
    • Insert the plastic opening tool into the bracket space on the back bottom left of the phone.
    • Gently twist tool clockwise until the back case pops open [this will create a small gap].
    • Slide the tool along the gap around the entire device.
  4. LG X Style Speaker  Replacement: passo 4, imagem 1 %32 LG X Style Speaker  Replacement: passo 4, imagem 2 %32
    • Insert the plastic opening tool into the indent below the battery, and pry up to lift and remove the battery.
  5. LG X Style Speaker  Replacement, Speaker: passo 5, imagem 1 %32 LG X Style Speaker  Replacement, Speaker: passo 5, imagem 2 %32 LG X Style Speaker  Replacement, Speaker: passo 5, imagem 3 %32
    • Insert the plastic opening tool into slit around speaker box on mid shield frame.
    • Gently pop up the speaker housing.
    • If the adhesive film doesn’t remove itself with the speaker housing, use the plastic opening tool to remove film.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 424
