Introdução
Use this guide to remove a faulty rear facing camera in your LG X Style.
O que você precisa
Power down the device and make sure that it is turned off.
Insert the plastic opening tool into the bracket space on the back bottom left of the phone.
Gently twist tool clockwise until the back case pops open [this will create a small gap].
Slide the tool along the gap around the entire device.
Gently use the plastic opening tool to pinch off camera connection tab from motherboard.
