Pular para o conteúdo principal
Introdução
This guide will show you how to replace the loud speaker on a LG X Power smartphone.
Peças
Nenhum componente especificado.
  1. Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off. Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off.
    • Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off.
  2. Remove the twelve 2.5mm Phillips #0 screws from the back of the phone. Remove the twelve 2.5mm Phillips #0 screws from the back of the phone.
    • Remove the twelve 2.5mm Phillips #0 screws from the back of the phone.
  3. Insert a plastic opening tool underneath the mid-frame and pry upwards until you hear a click. With the plastic opening tool still underneath the mid-frame, work your way around the perimeter until it's free from the smartphone.
    • Insert a plastic opening tool underneath the mid-frame and pry upwards until you hear a click.
    • With the plastic opening tool still underneath the mid-frame, work your way around the perimeter until it's free from the smartphone.
  4. Pry the loud speaker out of the mid-frame with a plastic opening tool. Pry the loud speaker out of the mid-frame with a plastic opening tool.
    • Pry the loud speaker out of the mid-frame with a plastic opening tool.
Conclusão
Uma outra pessoa concluiu este guia.
Chad Sears
Membro desde: 14-02-2018
899 reputação
5 Guias de autoria
Equipe
USF Tampa, Team S3-G6, Nance Spring 2018 Membro de USF Tampa, Team S3-G6, Nance Spring 2018
USFT-NANCE-S18S3G6
3 Membros
6 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 36
Todo: 588
