Ir para o conteúdo principal
LG Watch Urbane Battery Replacement
O que você precisa
  1. LG Watch Urbane Battery Replacement, Battery: passo 1, imagem 1 %32 LG Watch Urbane Battery Replacement, Battery: passo 1, imagem 2 %32
    • Push on the band in order to expose the pins
    • Using tweezers, remove the pins, one on each side, in order to only leave the face of the watch.
  2. LG Watch Urbane Battery Replacement: passo 2, imagem 1 %32 LG Watch Urbane Battery Replacement: passo 2, imagem 2 %32
    • Using plastic opening tools, carefully pry open the back cover of the the watch.
    • Use the little hatch on the bottom portion of the watch in order to easily pry open the watch
  3. LG Watch Urbane Battery Replacement: passo 3, imagem 1 %32 LG Watch Urbane Battery Replacement: passo 3, imagem 2 %32 LG Watch Urbane Battery Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Magnetic Project Mat
    $19.95
    Comprar
    • Using a PH000 screwdriver, remove the three screws in order to release the motherboard from the watch.
    • Do not lose the three screws! Keep them somewhere you will remember! A magnetic mat can help with this. Ifixit Magnetic Mat
    • Using plastic opening tools, remove the four connectors attached to the motherboard
  4. LG Watch Urbane Battery Replacement: passo 4, imagem 1 %32 LG Watch Urbane Battery Replacement: passo 4, imagem 2 %32 LG Watch Urbane Battery Replacement: passo 4, imagem 3 %32
    • Using the plastic opening tools, carefully lift up the motherboard.
    • IGNORE THIS STEP IF ONLY REMOVING MOTHERBOARD: Use the plastic opening tools to carefully remove the battery
Conclusão
18 outras pessoas executaram este guia.
Rey Diaz
Membro desde: 08/31/15
699 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 1-4, Remmell Fall 2015 Membro de USF Tampa, Team 1-4, Remmell Fall 2015
USFT-REMMELL-F15S1G4
Membros da 4
Autoria de 4 guias
11 comentários
"pried" not "pryed"
Patty Remmell - Responder
Where do I find a replacement battery?
nickpfau - Responder
Found mine on ebay. Search for BL-S3 battery.
Atreidae -
The reassembly requires gluing the back together. How do you get the glue?
jiteshshahin - Responder
There is glue around cover. I suppose when closing we should add glue to be waterproof again? Nothing about it in the guide, beside that ok.
Imx - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 38
Duração total: 15,380
