Introdução
Use this guide to replace the vent valve plunger in your LG WM3050CW Washing Machine.
The vent valve plunger vents moist air out the back of the washer. The plunger may stick open, which would allow excess liquid to slosh out and drip down the back of the washer.
O que você precisa
Turn off the main water supply
Unplug your washer
Disconnect all water connections at the rear of your washer
Use a Phillips driver to remove the two bottom 16.5 mm-long screws securing the top panel brackets.
Slide the top panel 1-2 inches towards the rear of the device to disconnect its clips.
To prevent confusion, label each valve and its corresponding hose.
Repeat the labelling procedure for each valve and its corresponding connector.
Disconnect the three spade connectors from the inlet valve.
Use needle nose pliers to pull the inlet valve filters straight out of the inlets in the chassis.
Remove the filters.
Use a Phillips driver to remove the two 14.4 mm‑long screws securing the inlet valve assembly.
Pull the inlet valve assembly straight out of its slot in the chassis to remove it.
Use a Phillips drive to loosen the screw securing the vent hose.
Lift the vent hose straight off the drum to expose the vent valve plunger.
Use two flathead screwdrivers, or similar tools, to pry the vent valve plunger up enough to grip it with your fingers.
Pull the plunger straight up to remove it.
Repair didn’t go as planned? Ask our Answers community for help.
