Ir para o conteúdo principal
LG Voyager Micro SD Replacement
O que você precisa
  1. LG Voyager Micro SD Replacement, Micro SD: passo 1, imagem 1 %32
    • Turn the phone onto its side so the label micro SD is facing upside down.
    • Once on its side, lift the micro SD cover up and swivel it away from the opening.
    Pergunte ao FixBot
    Comentar
  2. LG Voyager Micro SD Replacement: passo 2, imagem 1 %32 LG Voyager Micro SD Replacement: passo 2, imagem 2 %32
    • The Micro SD card will appear as a thin plastic piece sticking out of the phone
    • Gently push down on the card, you should hear a click, and then it will "spring" back at you.
    • The card should be sticking out of the phone slightly once this is done.
    • Remove the card from the slot
    Pergunte ao FixBot
    Comentar
Conclusão
Michelle
Membro desde: 04/10/12
20 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 17-26, Amido Spring 2012 Membro de Cal Poly, Team 17-26, Amido Spring 2012
CPSU-AMIDO-S12S17G26
4 Membros
Autoria de 4 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 15
Ao todo: 567
