Ir para o conteúdo principal
LG Voyager Antenna Replacement
O que você precisa
  1. LG Voyager Antenna Replacement, Battery: passo 1, imagem 1 %32
    • Turn over the phone so the front screen is facing down and the back side is up.
  2. LG Voyager Antenna Replacement: passo 2, imagem 1 %32
    • Pull down on the button at the bottom of the phone. The battery will pop up and can then be safely removed.
  3. LG Voyager Antenna Replacement: passo 3, imagem 1 %32
    • To install the new battery, position the battery so that the three small metal contacts of the battery are facing the three metal contacts of the phone
    • Insert the top of the battery, with the two plastic tabs, into their respective holes in the top
    • Then press down on the bottom of the battery and it should snap into place
  4. LG Voyager Antenna Replacement, Antenna: passo 4, imagem 1 %32
    • First remove the battery by pulling the tab away from the device
    • Next remove the 5 rubber modules by gently prying underneath them. This will expose the screws underneath
  5. LG Voyager Antenna Replacement: passo 5, imagem 1 %32 LG Voyager Antenna Replacement: passo 5, imagem 2 %32
    • Next remove the 6 #00 Phillips screws holding the back in place
    • screws: 1.43mm head, 3.61mm length
  6. LG Voyager Antenna Replacement: passo 6, imagem 1 %32 LG Voyager Antenna Replacement: passo 6, imagem 2 %32 LG Voyager Antenna Replacement: passo 6, imagem 3 %32
    • Now, slide a plastic opening tool in between the two plastic pieces that form the outside of the back case
    • Gently work the plastic opening tool around the edge of the case to separate the two pieces
    • Once the case has been separated you should be able to see the circuitry inside the phone
  7. LG Voyager Antenna Replacement: passo 7, imagem 1 %32 LG Voyager Antenna Replacement: passo 7, imagem 2 %32 LG Voyager Antenna Replacement: passo 7, imagem 3 %32
    • Remove the #00 Philips screw holding the antenna in place
    • Screw: 4.52mm length, 2.68mm head
    • Once the screw is removed, lift the small case around the antenna off
  8. LG Voyager Antenna Replacement: passo 8, imagem 1 %32 LG Voyager Antenna Replacement: passo 8, imagem 2 %32
    • Now that you have the antenna exposed, you can remove it
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team 17-26, Amido Spring 2012 Membro de Cal Poly, Team 17-26, Amido Spring 2012
CPSU-AMIDO-S12S17G26
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 291
