Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Follow the initial LG Vortex Disassembly guide before you begin camera replacement. This guide takes you step-by-step through the replacement of the LG Vortex camera.
O que você precisa
Find the two thumbnail ridges on the side and top of the phone. One is next to the micro SD slot and the other at the top of the phone
Once the ridges are located, use the blue plastic opening tool to pry the back cover away from the rest of the phone.
Remove the back cover and set it to the side.
Use the precision screwdriver to remove the 6 screws along the edges of the phone.
There are 2 screws at the top in each corner, 2 in the middle on the sides, and 2 in the bottom corners.
Use the blue plastic opening tool to remove the back frame from the rest of the phone.
Pry at the micro SD slot. Push the cover for the SD slot away from the front of the phone and pry the back frame away from the rest of the phone.
Pry your way around the entire phone to separate the face from the frame.
NOTE: This is the most difficult step.
Locate system board (silicone board with all of the circuitry on it). Notice that there is a black piece at the top of the system board (with the camera in it).
Use the pry bar to push the 2 black tabs away from the system board (located on the sides of the board). These tabs may snap back onto the board, so attempt to hold them off of the board.
Use the pry bar to pry the black piece at the top of the phone (looks to be attached to the system board, but is not).
4 comentários
First, clean the cookware with water and a mild kitchen soap to remove anything that might be on the surface. Rinse with hot water. I do uk.bestessays.com and Then coat the entire bottom of the pan in vegetable oil in this case, canola oil and turn it over onto a paper towel for 10 minutes.
Offer massages in my sanctuary or in the comfort of your own home
<a href="https://thecarriagehousesanctuary.square...">Top Massage Therapist in Westchester County NY</a>
Offer massages in my sanctuary or in the comfort of your own home <a href="https://thecarriagehousesanctuary.square...">Best Massage Therapist in Westchester County NY</a>
