Ir para o conteúdo principal
LG VX9800 LCD Screens Replacement
O que você precisa
  1. LG VX9800 LCD Screens Replacement, Front Keypad: passo 1, imagem 1 %32
    • Remove the two triangular pads at the top of the two speakers.
    • These pads have adhesive to keep them situated, so you may want to use a fine-tipped object, such as a screwdriver or a pen, to remove them. It is easiest to place the fine-tipped object in the small indent in the corner of these pads.
  2. LG VX9800 LCD Screens Replacement: passo 2, imagem 1 %32
    • Remove the two rubber cylinders from their shafts. These cover more screws.
    • This requires a little more effort, so you may need to "dig" them out.
  3. LG VX9800 LCD Screens Replacement: passo 3, imagem 1 %32
    • Now remove the four screws.
    • The screws are small, so put them somewhere that you can easily keep track of them.
  4. LG VX9800 LCD Screens Replacement: passo 4, imagem 1 %32
    • Starting on the side with blue square, pry the faceplate upwards with the flat end of a spudger.
    • Continue to slide the flat edge along the seam of the faceplate.
    • You should hear popping or snapping noises as the faceplate is being removed.
  5. LG VX9800 LCD Screens Replacement: passo 5, imagem 1 %32 LG VX9800 LCD Screens Replacement: passo 5, imagem 2 %32
    • The faceplate is attached by wires, so do not pull the faceplate very far away from the phone.
  6. LG VX9800 LCD Screens Replacement: passo 6, imagem 1 %32 LG VX9800 LCD Screens Replacement: passo 6, imagem 2 %32 LG VX9800 LCD Screens Replacement: passo 6, imagem 3 %32
    • The faceplate is still attached through speakers that travel from the ear-piece to the motherboard.
    • Carefully wedge the flat or pointed end of the spudger beneath the ear-piece and the faceplate.
    • This may require a bit of force, as the ear-piece is stuck to the faceplate with adhesive.
  7. LG VX9800 LCD Screens Replacement: passo 7, imagem 1 %32
    • The faceplate and keypad can now be completely removed from the phone.
  8. LG VX9800 LCD Screens Replacement, LCD Screens: passo 8, imagem 1 %32 LG VX9800 LCD Screens Replacement, LCD Screens: passo 8, imagem 2 %32 LG VX9800 LCD Screens Replacement, LCD Screens: passo 8, imagem 3 %32
    • Wedge the spudger into the small gap between the phone and the metal casing of the motherboard.
    • Slide the spudger underneath the metal and along the edge. The motherboard should begin to rise.
    • There is a ribbon at the end of this groove, do not slide the spudger into the ribbon.
    • Now use the spudger to lift the other side of the motherboard.
  9. LG VX9800 LCD Screens Replacement: passo 9, imagem 1 %32
    • Lift the motherboard at an angle.
    • Do not completely remove the motherboard. Doing so will tear the ribbon!
  10. LG VX9800 LCD Screens Replacement: passo 10, imagem 1 %32 LG VX9800 LCD Screens Replacement: passo 10, imagem 2 %32
    • Gently pull the LCD screen upwards.
    • It can be tricky do this, you may want to use a spudger to pry it up if it doesn't pull up easily.
    • This step requires soldering. Only do this step if you are OK with soldering small wires.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Aaron Rowley
Membro desde: 01/21/10
33 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 16-32, Maness Winter 2010 Membro de Cal Poly, Team 16-32, Maness Winter 2010
CPSU-MANESS-W10S16G32
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 2,247
