Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the back cover by sliding the tab away from the phone using one finger.
Lift one side of the battery using a plastic opening tool or your fingers.
Carefully remove the battery and set it aside.
Remove the nine 4 mm screws from the back cover with a Phillips #0 screwdriver.
Insert the tip of the iFixit opening tool into the small notch on the side of the case.
Slide the opening tool along the seam and around the edge of the phone to separate the case.
Hold the phone casing with one hand and the keypad assembly with the other.
Separate the phone casing from the keypad/motherboard.
Pull the two boards apart to separate the keypad from the motherboard.
Um comentário
When I separated the two halves a small brass piece came out and your instructions do not show nor mention what this is or where it goes. Not even a caution about it coming out upon separation of the halves. It appears to belong on one of the screw posts and because it is brass I believe it is supposed to complete a circuit.
