Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
The guide outlines the steps necessary to replace the Keypad in the LG VX8700. The keypad is used to to help direct what you are trying to do such as make a phone call.
O que você precisa
Remove the back cover by sliding the tab away from the phone using one finger.
Use a Phillips #0 Screwdriver to remove the nine 4 mm screws from the back cover.
Um comentário
When I separated the two halves a small brass piece came out and your instructions do not show nor mention what this is or where it goes. Not even a caution about it coming out upon separation of the halves. It appears to belong on one of the screw posts and because it is brass I believe it is supposed to complete a circuit.
