Ir para o conteúdo principal
LG VX8700 Keypad Replacement
O que você precisa
  1. LG VX8700 Keypad Replacement, Battery: passo 1, imagem 1 %32 LG VX8700 Keypad Replacement, Battery: passo 1, imagem 2 %32
    • Make sure the phone is completely off.
    • Remove the back cover by sliding the tab away from the phone using one finger.
  2. LG VX8700 Keypad Replacement: passo 2, imagem 1 %32 LG VX8700 Keypad Replacement: passo 2, imagem 2 %32
    • Lift one side of the battery using a plastic opening tool or your fingers.
    • Carefully remove the battery and set it aside.
    • When installing the new battery, make sure to align the metal pins with those of the phone.
  3. LG VX8700 Keypad Replacement, Keypad: passo 3, imagem 1 %32 LG VX8700 Keypad Replacement, Keypad: passo 3, imagem 2 %32
    • Remove the nine 4 mm screws from the back cover with a Phillips #0 screwdriver.
  4. LG VX8700 Keypad Replacement: passo 4, imagem 1 %32 LG VX8700 Keypad Replacement: passo 4, imagem 2 %32
    • Insert the tip of the iFixit opening tool into the small notch on the side of the case.
    • Slide the opening tool along the seam and around the edge of the phone to separate the case.
  5. LG VX8700 Keypad Replacement: passo 5, imagem 1 %32
    • Separate the two halves of the phone.
    • The back of the phone, which houses the motherboard and keypad, is displayed on the left.
    • The plastic casing is displayed on the right.
  6. LG VX8700 Keypad Replacement: passo 6, imagem 1 %32 LG VX8700 Keypad Replacement: passo 6, imagem 2 %32 LG VX8700 Keypad Replacement: passo 6, imagem 3 %32
    • Hold the phone casing with one hand and the keypad assembly with the other.
    • Separate the phone casing from the keypad/motherboard.
  7. LG VX8700 Keypad Replacement: passo 7, imagem 1 %32 LG VX8700 Keypad Replacement: passo 7, imagem 2 %32
    • Pull the two boards apart to separate the keypad from the motherboard.
Conclusão
tnscholz
Membro desde: 01/20/12
18 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 8-16, Maness Winter 2012 Membro de Cal Poly, Team 8-16, Maness Winter 2012
CPSU-MANESS-W12S8G16
Membros da 4
Autoria de 14 guias
Um comentário
When I separated the two halves a small brass piece came out and your instructions do not show nor mention what this is or where it goes. Not even a caution about it coming out upon separation of the halves. It appears to belong on one of the screw posts and because it is brass I believe it is supposed to complete a circuit.
gfon - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 724
