Pular para o conteúdo principal
Peças
Nenhum componente especificado.
  1. Turn the phone off. Remove the back cover by sliding the tab away from the phone using one finger.
    • Turn the phone off.
    • Remove the back cover by sliding the tab away from the phone using one finger.
  2. Lift one side of the battery using a plastic opening tool or your fingers.
    • Lift one side of the battery using a plastic opening tool or your fingers.
    • Carefully remove the battery and set it aside.
  3. When installing the battery, make sure to align the metal pins with those of the phone.
    • When installing the battery, make sure to align the metal pins with those of the phone.
  4. Kit de Reparo de Bateria do MacBook
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  5. Turn your phone around and open the flip phone.
    • Turn your phone around and open the flip phone.
    • Locate the two grey rubber plugs on the LCD portion of the phone. These plugs cover up two screws.
    • Remove the two grey screw-covers at the bottom of the screen
  6. Remove the screen by using the tab to eject the screen. There is a gap between the case and the screen near the ear piece
    • Remove the screen by using the tab to eject the screen.
    • There is a gap between the case and the screen near the ear piece
    • Insert the plastic opening tool in the gap and pry the screen up.
    • The plastic screen cover is glued onto the phone, do not be alarmed if it may be difficult to pry it off.
  7. Unscrew the four corner 3.21mm screws to separate the the top cover of the phone
    • Unscrew the four corner 3.21mm screws to separate the the top cover of the phone
  8. Turn your phone around Remove the top cover of the phone by inserting the plastic opening tool into the groove.
    • Remove the top cover of the phone by inserting the plastic opening tool into the groove.
    • Carefully open the cover.
Conclusão
Stanley Thomas
Membro desde: 20-01-2012
38 reputação
4 Guias de autoria
Equipe
Cal Poly, Team 8-16, Maness Winter 2012 Membro de Cal Poly, Team 8-16, Maness Winter 2012
CPSU-MANESS-W12S8G16
4 Membros
14 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 900
