Ir para o conteúdo principal
LG VX8700 Ear Piece Replacement
O que você precisa
  1. LG VX8700 Ear Piece Replacement, Battery: passo 1, imagem 1 %32 LG VX8700 Ear Piece Replacement, Battery: passo 1, imagem 2 %32
    • Make sure the phone is completely off.
    • Remove the back cover by sliding the tab away from the phone using one finger.
  2. LG VX8700 Ear Piece Replacement: passo 2, imagem 1 %32 LG VX8700 Ear Piece Replacement: passo 2, imagem 2 %32
    • Lift one side of the battery using a plastic opening tool or your fingers.
    • Carefully remove the battery and set it aside.
    • When installing the new battery, make sure to align the metal pins with those of the phone.
  3. LG VX8700 Ear Piece Replacement, Front Bezel: passo 3, imagem 1 %32
    • Turn your phone around and open the flip phone.
    • Locate the two grey rubber plugs on the LCD portion of the phone. These plugs cover up two screws.
    • Remove the two grey screw-covers at the bottom of the screen
  4. LG VX8700 Ear Piece Replacement: passo 4, imagem 1 %32 LG VX8700 Ear Piece Replacement: passo 4, imagem 2 %32
    • Remove the screen by using the tab to eject the screen.
    • There is a gap between the case and the screen near the ear piece
    • Insert the plastic opening tool in the gap and pry the screen up.
    • The plastic screen cover is glued onto the phone, do not be alarmed if it may be difficult to pry it off.
  5. LG VX8700 Ear Piece Replacement: passo 5, imagem 1 %32
    • Unscrew the four corner 3.21mm screws to separate the the top cover of the phone
  6. LG VX8700 Ear Piece Replacement: passo 6, imagem 1 %32 LG VX8700 Ear Piece Replacement: passo 6, imagem 2 %32
    • Remove the top cover of the phone by inserting the plastic opening tool into the groove.
    • Carefully open the cover.
  7. LG VX8700 Ear Piece Replacement, Ear Piece: passo 7, imagem 1 %32
    • Desolder the top ear piece using a soldering iron to remove the component
    • The ear piece is the black component that is located at the top with black and red wires
  8. LG VX8700 Ear Piece Replacement: passo 8, imagem 1 %32 LG VX8700 Ear Piece Replacement: passo 8, imagem 2 %32
    • Remove the ear piece from the phone by lifting it using a plastic opening tool.
Conclusão
Stanley Thomas
Membro desde: 01/20/12
41 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 8-16, Maness Winter 2012 Membro de Cal Poly, Team 8-16, Maness Winter 2012
CPSU-MANESS-W12S8G16
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 989
