Ir para o conteúdo principal
LG VX8560 Side Key Replacement
O que você precisa
  1. LG VX8560 Side Key Replacement, Battery: passo 1, imagem 1 %32
    • Flip the phone over so its backside is facing up
  2. LG VX8560 Side Key Replacement: passo 2, imagem 1 %32
    • Push the battery cover from the indentation and slide the battery cover away from phone to remove battery cover
  3. LG VX8560 Side Key Replacement: passo 3, imagem 1 %32 LG VX8560 Side Key Replacement: passo 3, imagem 2 %32
    • Remove the battery from the phone
  4. LG VX8560 Side Key Replacement, Side Keys: passo 4, imagem 1 %32 LG VX8560 Side Key Replacement, Side Keys: passo 4, imagem 2 %32
    • Using a Phillips #00 screwdriver, remove all four screws that are visible along the edge of the phone
  5. LG VX8560 Side Key Replacement: passo 5, imagem 1 %32 LG VX8560 Side Key Replacement: passo 5, imagem 2 %32 LG VX8560 Side Key Replacement: passo 5, imagem 3 %32
    • Find the seam between the phone’s keypad cover and back cover, and slide a plastic pry tool along the edge to gently pry the two pieces apart without completely separating them.
    • The motherboard should be visible. Do not separate the two covers. They should be held together by a screw at the axis of the phone.
  6. LG VX8560 Side Key Replacement: passo 6, imagem 1 %32 LG VX8560 Side Key Replacement: passo 6, imagem 2 %32
    • Place the side keys so that they are aligned with the silver circles located on the side of the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
Kevin
Membro desde: 04/18/13
7 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 13-62, Johann Spring 2013 Membro de Cal Poly, Team 13-62, Johann Spring 2013
CPSU-JOHANN-S13S13G62
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 21
Duração total: 232
