Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the 2 screw covers next to the rear speaker with a Push Pin.
Remove the 4 cover screws with a Philips #00 screwdriver.
Use the iPod opening tool to pry off the back casing.
Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
With the back casing removed the speaker is visible.
Lift up under top end of circuit board with the Spludger to access retaining clip.
Carefully pry up on retaining clip with the Spudger to release the speaker.
