Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Steps to remove the LG VX8550 scroll wheel
O que você precisa
Remove the 2 screws from the back of the phone with a Phillips #00 Screwdriver.
Lay the phone with the screen facedown.
The 6 slider screws are visible.
Remove the 2 screw covers next to the speaker with a push pin next to the camera.
With the spudger, lift up under the connector to unplug it from the circuit board.
Carefully lift the circuit board away from the screen casing using Ipod Opening Tool.
Peel the circuit board away from the adhesive backing with your finger.
Uma outra pessoa concluiu este guia.
