Ir para o conteúdo principal
LG VX8550 Keypad Housing Replacement
O que você precisa
  1. LG VX8550 Keypad Housing Replacement, Battery: passo 1, imagem 1 %32
    • Slide the battery release up.
  2. LG VX8550 Keypad Housing Replacement: passo 2, imagem 1 %32
    • Remove the battery by lifting away from the case.
  3. LG VX8550 Keypad Housing Replacement, Case: passo 3, imagem 1 %32
    • Remove the 2 screw covers next to the rear speaker with a Push Pin.
  4. LG VX8550 Keypad Housing Replacement: passo 4, imagem 1 %32
    • Remove the 4 cover screws with a Philips #00 screwdriver.
  5. LG VX8550 Keypad Housing Replacement: passo 5, imagem 1 %32
    • Use the iPod opening tool to pry off the back casing.
  6. LG VX8550 Keypad Housing Replacement: passo 6, imagem 1 %32
    • Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
  7. LG VX8550 Keypad Housing Replacement: passo 7, imagem 1 %32
    • Separate the casing halves.
    • Be sure to keep track of the side buttons as they fall out.
  8. LG VX8550 Keypad Housing Replacement, Motherboard: passo 8, imagem 1 %32
    • Remove the 2 screws from the back of the phone with a Phillips #00 Screwdriver.
  9. LG VX8550 Keypad Housing Replacement: passo 9, imagem 1 %32
    • Carefully lift up on the motherboard to see the ribbon cables underneath.
    • Use the spudger to carefully disconnect the ribbon cable from the motherboard.
  10. LG VX8550 Keypad Housing Replacement: passo 10, imagem 1 %32
    • Remove the motherboard from the front casing by lifting straight up.
  11. LG VX8550 Keypad Housing Replacement, Keypad Housing: passo 11, imagem 1 %32
    • Lay the phone with the screen facedown.
    • The 6 slider screws are visible.
  12. LG VX8550 Keypad Housing Replacement: passo 12, imagem 1 %32
    • Peel back but don't remove the blue tape to access the 2 center screws.
    • Remove the 6 slider screws with the Phillips #00 screwdriver.
  13. LG VX8550 Keypad Housing Replacement: passo 13, imagem 1 %32
    • Lift the keypad housing away from the slider.
Conclusão
Nathan Jones
Membro desde: 04/10/10
89 Reputação
Autoria de 10 guias
Equipe
Cal Poly, Team 34-55, Forte Spring 2010 Membro de Cal Poly, Team 34-55, Forte Spring 2010
CPSU-FORTE-S10S34G55
Membros da 5
Autoria de 20 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 15
Duração total: 1,933
