Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Steps to remove the LG VX8550 camera
O que você precisa
Remove the 2 screws from the back of the phone with a Phillips #00 Screwdriver.
Lay the phone with the screen facedown.
The 6 slider screws are visible.
Remove the 2 screw covers next to the speaker with a push pin next to the camera.
With the screen casing separated from the slider mechanism the camera circuit board is visible.
Carefully lift up on the connector to unplug it from the circuit board.
