Ir para o conteúdo principal
LG VX8550 Camera Replacement
O que você precisa
  1. LG VX8550 Camera Replacement, Battery: passo 1, imagem 1 %32
    • Slide the battery release up.
  2. LG VX8550 Camera Replacement: passo 2, imagem 1 %32
    • Remove the battery by lifting away from the case.
  3. LG VX8550 Camera Replacement, Case: passo 3, imagem 1 %32
    • Remove the 2 screw covers next to the rear speaker with a Push Pin.
  4. LG VX8550 Camera Replacement: passo 4, imagem 1 %32
    • Remove the 4 cover screws with a Philips #00 screwdriver.
  5. LG VX8550 Camera Replacement: passo 5, imagem 1 %32
    • Use the iPod opening tool to pry off the back casing.
  6. LG VX8550 Camera Replacement: passo 6, imagem 1 %32
    • Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
  7. LG VX8550 Camera Replacement: passo 7, imagem 1 %32
    • Separate the casing halves.
    • Be sure to keep track of the side buttons as they fall out.
  8. LG VX8550 Camera Replacement, Motherboard: passo 8, imagem 1 %32
    • Remove the 2 screws from the back of the phone with a Phillips #00 Screwdriver.
  9. LG VX8550 Camera Replacement: passo 9, imagem 1 %32
    • Carefully lift up on the motherboard to see the ribbon cables underneath.
    • Use the spudger to carefully disconnect the ribbon cable from the motherboard.
  10. LG VX8550 Camera Replacement: passo 10, imagem 1 %32
    • Remove the motherboard from the front casing by lifting straight up.
  11. LG VX8550 Camera Replacement, Keypad Housing: passo 11, imagem 1 %32
    • Lay the phone with the screen facedown.
    • The 6 slider screws are visible.
  12. LG VX8550 Camera Replacement: passo 12, imagem 1 %32
    • Peel back but don't remove the blue tape to access the 2 center screws.
    • Remove the 6 slider screws with the Phillips #00 screwdriver.
  13. LG VX8550 Camera Replacement: passo 13, imagem 1 %32
    • Lift the keypad housing away from the slider.
  14. LG VX8550 Camera Replacement, Front Case: passo 14, imagem 1 %32
    • Remove the 2 screw covers next to the speaker with a push pin next to the camera.
  15. LG VX8550 Camera Replacement: passo 15, imagem 1 %32
    • Remove the 6 screws with a Phillips #00 Screwdriver.
  16. LG VX8550 Camera Replacement: passo 16, imagem 1 %32
    • Use the ipod opening tool to pry the screen casing and the slider mechanism apart from each other.
  17. LG VX8550 Camera Replacement: passo 17, imagem 1 %32
    • Carefully lift the slider mechanism to see the ribbon cables underneath.
  18. LG VX8550 Camera Replacement: passo 18, imagem 1 %32
    • Slide ribbon cable through the slider mechanism.
  19. LG VX8550 Camera Replacement: passo 19, imagem 1 %32
    • Separate the two halves.
  20. LG VX8550 Camera Replacement, Camera: passo 20, imagem 1 %32
    • With the screen casing separated from the slider mechanism the camera circuit board is visible.
    • Carefully lift up on the connector to unplug it from the circuit board.
  21. LG VX8550 Camera Replacement: passo 21, imagem 1 %32
    • Lift up slowly on the connector cable to peel the camera off the adhesive backing.
  22. LG VX8550 Camera Replacement: passo 22, imagem 1 %32
    • Remove camera from the casing.
Conclusão
Nathan Jones
Membro desde: 04/10/10
89 Reputação
Autoria de 10 guias
Equipe
Cal Poly, Team 34-55, Forte Spring 2010 Membro de Cal Poly, Team 34-55, Forte Spring 2010
CPSU-FORTE-S10S34G55
Membros da 5
Autoria de 20 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 1,412
