Ir para o conteúdo principal
LG VX8300 Battery Replacement
  1. LG VX8300 Battery Replacement, Battery Replacement: passo 1, imagem 1 %32 LG VX8300 Battery Replacement, Battery Replacement: passo 1, imagem 2 %32 LG VX8300 Battery Replacement, Battery Replacement: passo 1, imagem 3 %32
    • Power off the device by holding down the power button.
    • Remove the battery cover by pushing down on the solid lines at the top of the cover. Then simply slide the cover down till it is completely removed.
  2. LG VX8300 Battery Replacement: passo 2, imagem 1 %32 LG VX8300 Battery Replacement: passo 2, imagem 2 %32 LG VX8300 Battery Replacement: passo 2, imagem 3 %32
    • Place your finger into the semicircle gap at the top of the battery, then push down and pull so the battery pops out.
  3. LG VX8300 Battery Replacement: passo 3, imagem 1 %32
    • Wipe down the battery compartment to remove any debris or battery acid. Avoid contact with battery acid as it can damage your eyes or skin.
  4. LG VX8300 Battery Replacement: passo 4, imagem 1 %32
    • Insert the new Lithium Ion 3.7V 1100mAh battery into the compartment.
Conclusão
After you finish replacing the battery make sure you put the battery cover back on and you will be all set.
nvalm
Membro desde: 03/23/15
448 Reputação
Autoria de 4 guias
Equipe
UMass Dartmouth, Team 3-7, Duarte Spring 2015 Membro de UMass Dartmouth, Team 3-7, Duarte Spring 2015
UMASSD-DUARTE-S15S3G7
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 525
